help me ,,my PROBING allways report an error 1. Solution exception:Failed to find the path “C:\Eddy3D-Cases\3_SimpleWindAnalysis\0\constant\polyMesh”.My EDDY3D installed version is0.4.2.0,BlueCFD also is v.2020. I don’t konw how can I solve this problem…
Did you solve it? I have the same issue
Hi, I have the same problem, did anyone solve this yet?
If the polyMesh folder cannot be found, it means that you do not have a mesh.
@patrick.kastner Halo Patrick, thank you for the answer.
Unfortunately, I was new to this CFD and Grasshopper. Could you describe how to create a mesh for CFD simulation in eddy3D? I really appreciate your help.
