[HELP] Issue regarding run mesh and run simulation
Hi
I ran into a very similar problem as this one: Help me ,,PROBING allways report an error: Failed to find the path - #5 by Taufiq_Ihsan_Ismail
The first thing I noticed when I pulled up the simple wind template was that the probing said “solution exception: Could not find a part of the path ‘C:\……’ as shown in the image
So I updated all components in the template by redrawing the entire map with the current batteries, which was not helpful.
Then I noticed the issue may be caused by the simulation component. After setting run mesh and run sim, two cmd windows flashed.
20251117_22240000h00m00s-00h00m08s
both of the cmd window says “The system can’t find the directory properly”
I have tried to reinstall the BlueCFD, and I have tried both BlueCFD 2020 and 2024, but neither of them worked.
my rhino8 version is Rhino8 SR24
(8.24.25281.15001, 2025-10-08)
Educational
My grasshopper version is 1.0.0008
my Blue CFD version is blueCFD-Core 2020-1, and installed under C:\blueCFD-Core\2020
my Eddy3D version is 0.4.15.13
Could you please help me take a look?
Thanks
test1.gh (27.0 KB)
