Help Installing Grasshopper plugin gha file (ShapeMap)
I’m having trouble getting the ShapeMap plugin installed in Grasshopper. I’ve gone to Special Folders/Components Folder and copied the gha file and the dll files there (maybe they should be in a sub folder?).
I close Rhino and reopen and then open grasshopper, but the ShapeMap tab isn’t there. Anyone know how I can get this plugin installed?
Thank you,
Sam
You can install it with PakageManager.
Folder:
C:\Users\(name)\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\ShapeMap\1.0.4\ShapeMap1.0.gha
Okay, I see it now. I installed it in the package manager and restarted rhino, but got the following errors in the command prompt when starting grasshopper (and no tab for ShapeMap…)
Suggestions?
Could you run the SystemInfo in the command line of Rhino 8 and post all popup content here ? Thanks.
Rhino 8 SR15 2025-1-19 (Rhino 8, 8.15.25019.13001, Git hash:master @ 74164bdf5469c2f269746857c54b8c44b74c7b24)
License type: Commercial, build 2025-01-19
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET Framework 4.8.9290.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 8-14-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.94
Secondary graphics devices.
Intel(R) UHD Graphics 750 (Intel) Memory: 2GB, Driver date: 9-13-2024 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-14-2024
Driver Version: 32.0.15.6094
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Users\Sam\Documents\3DShoemaker\PodoCAD\PodoCAD\Bin\3DShoemaker.rhp “3DShoemaker” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\export_STL.rhp “STL Export”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.15.25019.13001
Thanks for your information. Please run the command SetDotNetRuntime in the command line of Rhino, and set Runtime = NET Core NetCoreVersion=v7
SetDotNetRuntime
That did it, thanks!
