ShapeMap 1.1.0 throws an error and the plugin can't run
Screenshot of the error.
As I understand it, I installed the latest SDK version, 7.0.410, due to problems with the SDK.
I enabled Rhino with SDK 7.0.410.
It still returns an error.
I’m sorry to inform you that ShapeMap only supports Rhino 8 (Win). Please test it in the latest Rhino 8.24. Thank you.
I have the latest version of Rhino.
I selected this option. The error no longer appears. But the icons are missing.
Could you please confirm if you restart Rhino 8 after running SetDotNetRuntime ? If the issue presists, please run SystemInfo in the command line of Rhino, and copy-past all pop-up content here. Thank you.
Rhino 8 SR25 2025-10-14 (Rhino 8, 8.25.25287.14001, Git hash:master @ 6cb5f028371cc144f33593b4e8884e14e4ebc7e9)
License type: Commercial, build 2025-10-14
License details: Stand-Alone
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET Framework 4.8.9310.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4080 (NVidia) Memory: 16GB, Driver date: 8-21-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 581.15
Accelerated graphics device with 4 adapter port(s)
  • Secondary monitor attached to adapter port #0
  • Windows Main Display attached to adapter port #1
  • Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-21-2025
Driver Version: 32.0.15.8115
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Gemvision\MatrixGoldRhino8\MatrixGoldPlugin\MatrixGoldPlugin.rhp “MatrixGoldPlugin” 3.8.24093.1001
C:\Program Files\ClayooRhino6\System\Clayoo.rhp “Clayoo” 2.6.19024.1
C:\Program Files\Gemvision\MatrixGoldRhino8\MatrixGoldRenderPlugin\MatrixGoldRenderPlugin.rhp “MatrixGoldRenderPlugin” 1.0.0.0
C:\Users\roman\AppData\Local\McNeel\Rhinoceros\8.0\Plug-ins\Thea For Rhino (0ab51401-0ca2-45e3-94e0-46d77b129353)\4.0.229.153\TheaForRhino8.rhp “Thea For Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.25.25287.14001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.25.25287.14001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.25.25287.14001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.25.25287.14001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.25.25287.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.25.25287.14001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.25.25287.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.25.25287.14001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.25.25287.14001
Thank you for your information. Please try to restart Rhino 8 and run GrasshopperLoadOneByOne in the command line of Rhino, then say No to all third-part GH plug-ins but ShapeMap.
Now it works!!! But how do I figure out which plugin is conflicting? Because I use a lot of third-party plugins.
Sounds great! But I’m sorry to infrom you that you need to disable all third-party plugins except ShapeMap one by one.
Hi Roman -
This will be trial-and-error by enabling one plug-in at a time.
