Help! How to create the MAAT museum pattern in Grasshopper?
I would like to model the pattern for the MAAT museum in portugal, on a double curved surface, using Grasshopper.
IIt is basically a shifted/staggered/ hexagon, but you could also look at it as a trapezoid shape.
The final goal will be to create the pattern using to most amount of identical panels, and minimize the amount of different sized panels.
They also should be all planar.
I have tried using NGon Plugin, Paneling tools for Rhino, and Kangaroo, but could not seem to figure any of those scripts out
I have read these threads, but they have many different-sized panels, and the goal is go have as many identical panels as possible
https://discourse.mcneel.com/t/ngon-extracting-and-grouping-extruded-panels-as-solids/80664https://agatakycia.com/2014/09/22/___best-paper-award-aag-2014-london/
Here is the surface I have to add the panels:
MAAT Surface.3dm (165.6 KB)
Need some help!
Thanks!!
hi, Ortiz
Trying to use some simple lines to draw the texture on the surface and then volumn it. hope it helps.
best
Well, Idk how do you want to trim the tiles exactly, but heres one way to do this:
maat_dfytz.gh (16.4 KB)
it can be much faster, I just went straight to the result.
upd: Oh, I did not read any of this XD
Blockquote
2nd version, planar surfaces, all different
maat2_dfytz.gh (28.8 KB)
is the tiles double-curved surface. thats looks not planarized surface… how they made the tiles?
Is there had a tiles version of gasshapper? thx
