Help! Cannot select anyting by clicking
This is very strange behavior and it happens only in this instance.
I cannot select anything by clicking.
I can SelRectangular, but just by clicking on the geometry doesn’t work.
In the videos below I am clicking several times and then I use rectangular selection:
The geometry is not locked.
It happens in both 2D and 3D viewports…
Zoom Extend tells me that no objects are visible even though there are…
Looks like u locked the View, maybe try “_unlock”
nope, I tried already
try reset your views:
“_4View”
Your model is a long way from the origin. Does selection work normally if you move everything close to it?
Yes, @jeremy5 ,
Once more I got confused by the model being too far away from origin.
I moved it close and now i can select as normal.
Is there any fix for this problem of stuff being too far away? Maybe changing the world origin?
It isn’t something that comes up in my normal use of Rhino so I’m not the person to ask about best practice. But I’m wondering why you have these large millimetric distances. Are you forced to work in millimetres rather than metres?
Architecture is always done in millimetres. And if I have several variations next to eachother I end up with those large distances - which work very well i have to say, thumbs up for Rhino.
In this particular case I think I copy-pasted some block geometry from another file, and that’s how I actually got to those immense distances.
