PLS HELP ASAP FINALS!!! Can someone please tell me how I can get rid of these lines on the top left white rectangle? It’s a 4pts to surface command – extruding a rectangle doesn’t work because there’s a small issue with my model where one of the lines is not quite straight vertical. I need it to be a plain white with no linework when I print to make it look clean!
Hmmm.
Looks like ou got rid of the lines… and the picture!
Please check your post.
oops ur right, new post – same but with pic if you can help!
