hello, I try to understand how can I do to make an helix with a form who stay the same until te beginning to the end… Someone can help me?
Please look the rhino file,
best regards,
Nicolastest.3dm (2.7 MB)
best regards,
Is this not just a regular helix made with the Helix command?
Yes it is done with the simple helix but I don’t arrive to make an helix with the square and that it stay right
Thanks a lot
Hello - I am not sure I understand the request yet but possibly something like the attached file?
Helix_Maybe.3dm (38.6 KB)
thank you pascal Goley but it is not what I would like to mean…
please find what I search
As a start, use the command “Spiral” to create the basic cone. Then copy the spiral in the vertical, at a distance equal to the step height. Create a vertical square with two points touching on the ends of both spiral curves, and use Sweep2 to create the shape. You will have to experiment a bit to get the top and bottom parts right.
I do not know what exactly you are designing, but keep in mind that a shape like this has an ever increasing steepness towards the top.
Max.
edit: procedure changed to get a more accurate shape.
thanks a lot, it is exactly what I was searching
