Hatch Problem
I’ve been trying to hatch the walls and footing on a simple house section however every time I select and apply the hatch it always comes out as solid black. Does anyone know what’s going on here?
Thanks
Hello - the default hatch is solid - you get to pick from a list - either at creation time or afterwards in Properties - if the hatch is not solid in theory, but looks solid, you may need to scale it up in its Properties.
thank you thank you. Scaling up was the trick!
