Every 20 minutes or so Rhino will just stall for me when I am in shaded mode. Everything will freeze for 10 or 15 seconds. It doesn’t matter what size the file is. I have a fairly new computer with 8gb of gpu. The cpu is an 8 core ryzen. This has only been happening this year. It is not autosave.
I suspect you need a graphic driver update (or two), but it could be a plug-in.
How many monitors are you running and at what resolution?
Please run Rhino V6’s SystemInfo command and post the results.
That will give us a good overview or your setup.
Just one monitor. It is a 4k monitor. An all in one Dell inspiron 7775.
Rhino 6 SR22 2020-1-28 (Rhino 6, 6.22.20028.13281, Git hash:master @ 379871ece695dc096e83826f08b429db8ca2e7f5)
License type: Commercial, build 2020-01-28
License details: Cloud Zoo. In use by: Intuitionusa ()
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: DELLBIGDADDY
Non-hybrid graphics.
Primary display and OpenGL: Radeon ™ RX 580 Graphics (AMD) Memory: 8GB, Driver date: 1-18-2018 (M-D-Y). OpenGL Ver: 4.5.13506 Compatibility Profile Context 23.20.15016.15
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50
Driver Date: 1-18-2018
Driver Version: 23.20.15016.15
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.22.20028.13281
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 6\Plug-ins\export_STL.rhp “STL Export”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\ColorPicker (336da4ab-03d3-42ca-b1fb-313bfd4c1157)\2018.2.5.819\ColorPicker.rhp “ColorPicker”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.22.20028.13281
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.6.14.669\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 6\Plug-ins\import_STEP.rhp “STEP Import”
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.22.20028.13281
C:\Program Files\Rhino 6\Plug-ins\import_STL.rhp “STL Import”
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.22.20028.13281
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
Your display driver is quite old.
Here’s a lilnk to a new driver released earlier today:
https://www.amd.com/en/support/graphics/radeon-500-series/radeon-rx-500-series/radeon-rx-580
There are a couple of suspect plug-ins, but the most likely cause is the old AMD driver.
Any luck?
Hmm I’ve seen something like this too…my Nvidia driver is a little old, will update and see.
I updated my driver and my machine did not like it. The mouse can not even go smoothly across the screen without a lag without Any programs open. I did the auto install.
went to the dell website and downloaded a driver for my machine and now it works. It auto detected it.
