Gumball Multiple Copies
Hi everyone,
I was wondering if it would be possible to implement a feature in the Gumball similar to something available in SketchUp.
Currently, when using the Gumball to move an object, we can enter a distance manually, like “150” to move it 150 units. It would be extremely useful if Rhino could also support expressions like “150*5”, which would result in the object being copied 5 times, each at a distance of 150 units.
This is a feature in SketchUp that significantly speeds up repetitive modeling tasks, and I think it could greatly enhance workflow efficiency in Rhino as well.
Is this something that could be considered for a future update? Or maybe there’s already a way to achieve this that I’m not aware of?
Thanks in advance!
Unfortunately that syntax is already used because pretty much all places that support numerical entry in Rhino now allow calculations like addition, multiplication, division etc. So if you enter 150*5 it will move the objects 750 units.
Without the gumball, the typical way of doing this is with an array.
the copy command can do this-
pick an object,
pick the start point, then either enter a distance, in your case 150 units. or drag a distance.
place the first one with a left click.
now, notice in the command line the command is still running but now has some options.
set the commands like this:
use last distance to yes,
from last point to yes.
use last direction to yes.
clickty click as many copies as you want all perfectly spaced.
Dear all,
thank you everyone for your suggestions.
We were aware of these functions, but we were hoping to reduce the number of clicks with a tool similar to the “SKP method,” which indeed accelerates the modeling process.
I remain confident that similar improvements could be considered in future updates.
Thanks again!
