Hello!
I have used “rs.RotateObject” to generate a point(a guid of a point). and i have a point (Point3d).
i want to use “rs.AddCurve” to add a curve to my Rhino but this is the error I have gotten from:
I wonder if someone knows the solution for that
Well, it sounds like you’re still trying to pass a GUID (probably a Rhino point in the document) and not a Point3d. I don’t know what your function CurveDivider() returns (you don’t show it), but check what’s actually in the list points that you are getting from that function.
but is there any way yo convert these two(Guid and point,d) to each other?
in my case “Point_on_Barriers” is a list of point3d
and
“g” is a Guid coming from “rs.RotateObject”
the weird thing is based on the Help
“rs.AddCurve” can work with both point3d and Guid (if i have understood right)
The easiest way is probably to use
my_point3d=rs.coerce3dpoint(guid)
That’s because most of the rhinoscriptsyntax methods that can take points use rs.coerce3dpoint internally.
Dunno, this works here:
pt_id=rs.GetObject("Pick a point object",1,preselect=True)
print type(pt_id),pt_id
my_pt=rs.coerce3dpoint(pt_id)
print type(my_pt),my_pt
