Get Geometry details from guid
I wanted to get geometry details(programatically) such as coordinates of a point/object by passing guid of that object. Please help me with solution
Note:
I am using Rhino6 and grasshopper is not used here, also its appreciated if the solution provided doesn’t use grasshopper
Hi @sumuk,
You should indicate, which programming language you are using!
If you’re coding in python, you could achieve this by coercing your GUID to the corresponding geometry type:
import random
# Add a random point guid
x = random.randint(0, 10) # random integer between 0 and 10
y = random.randint(0, 10) # random integer between 0 and 10
z = random.randint(0, 10) # random integer between 0 and 10
pt_id = rs.AddPoint( (x,y,z) )
# Coerce guid to point
pt = rs.coerce3dpoint(pt_id)
# Get the point coordinates
x, y, z = pt
Another possibility would be to use rhinocommon, instead of rhinoscriptsyntax, to avoid having to deal with coercions and guids.
An example could look like this:
import Rhino.Geometry as rg
import random
# Construct a random point
pt = rg.Point3d(x, y, z)
x, y, z = pt
Happy holidays! :santa:
