Hi there,
I use the rhinoscriptsyntax command DivideCurve(objID, parameter, create_points=True, return_points = True)
to divide a curve (objID). The problem that I face is that I cannot get the guid of the points created by the above-mentioned command. How do you think that this could be possible. I know that with GetPoints() command I could take the guid of each point, however, I would like to automate the process since I have many points.
Thanks a lot,
giorgos
