Hi V8 and v5 I create points an a planar wavy line (from section through mesh) I group the points run circle through points, select the group and it only selects one point. The idea of easy select with them grouped is gone.
same issue in v5 as in v8.
Why ?
Cheers
Steve
As a workaround, you can preselect the points before running Circle FitPoints, but it does seem like this ought to honor object grouping.
Circle FitPoints
Hi Steve -
Thanks → RH-84952 Circle: FitPoints - Accept Group Input -wim
RH-84952 is fixed in Rhino 8 Service Release 15
