Does anyone knows how I can do this on Rhino 5?
Hi Marcel - that would be a job for Grasshopper, possibly.
Thank you Pascal.
This has convinced me to get Rhino 6 because it includes Grasshopper. I am good at Rhino 5 but I never learned Grasshopper so now I will.
Thanks again.
Marcel
Hello for the grid you could use that
http://xahlee.info/SpecialPlaneCurves_dir/Inversion_dir/inversion.html
Or what was done here but it needs another transformation from 3D to 2D
hi
Thank you for your reply.
I cannot access it as it tells me: _“you connection is not private”
Hi and with this link ?
https://www.grasshopper3d.com/forum/topics/surface-from-curve-netwrok
But grid inversion is what you need, it is very simple to make with grasshopper using point deform for Example. As it is interesting I will surely make something this weekend
You can still install grasshopper for Rhino 5.
There was a discussion on that on this forum
Still not!
I must tell you that I don’t have GH yet. I just purchased Rhino6 and waiting to get it ( perhaps Monday). I just thought your link would have been a tutorial video.
Some images with squares
And first reference from
Marc Didou, Anamorfosi 4, 2013, acciaio corten, cm 75x60
http://www.arte.it/calendario-arte/milano/mostra-pars-oculi-34451
Merci Laurent. Je n’ai pas encore Grasshopper mais je l’aurai Lundi ou Mardei. Si vou pouviez me donner le script pour faire le “grill like a photo”, cela m’aiderais beaucoup.
SIncerement
Marcel
Hello
here is the script. It uses a grid of closed polylines (it could be curves). These curves are then centered and inversed via a graph mapper. It is more versatile than the equation of inversion.
For non-Grasshopper solutions, you could try the Flatworms plugin that was designed to explore curve-network based patterns:
–jarek
