when I load grasshopper as of the latest build Version 6 WIP (6.15.19078.12066, 2019-03-19), the window is completely blank.
the rhino window reflects that the file is loaded and working.
Hi @dasiv
We just put out a more recent RhinoWIP. Give that a try.
That said, I doubt that will solve your problem…but best to get up-to-date.
Once you have updated, please run the SystemInfo command in Rhino proper and paste the results back in here. That might give us clues to why you are getting a blank window.
thank you for the prompt response! info appended below.
Rhino 6 SR15 2019-3-27 (Public Build, 6.15.19086.9026, Git hash:master @ 516494bd0d69bd30a3f93628ca573422d231775c)
License type: Beta, build 2019-03-27
License details: Stand-Alone
Expires on: 2019-05-11
Apple Intel 64-bit macOS Version 10.13.6 (Build 17G5019) (Physical RAM: 64Gb)
Mac Model Identifier: MacPro5,1
Machine name: dodecagonadon
Language: en-US (MacOS default)
ATI Radeon HD 5870 OpenGL Engine (OpenGL ver:4.1 ATI-1.68.21)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
Graphics: ATI Radeon HD 5870
Displays: SMB2430H (92dpi 1x), SMB2430H (92dpi 1x), S22B420 (92dpi 1x)
Graphics processors
ATI Radeon HD 5870 (1024 MB)
SMB2430H (1920 x 1080 @ 60 Hz)
S22B420 (1050 x 1680 @ 60 Hz)
USB devices
Apple Inc.: Apple Keyboard
Apple Inc.: Bluetooth USB Host Controller
3Dconnexion: SpaceExplorer
Bluetooth devices
None
Third party kernel extensions
com.3dconnexion.driver (10.5.1) 23F2462E-B272-3BBC-A8DC-BEE242EE3FA7
at.obdev.nke.LittleSnitch (5264) A3F04A53-C3F3-33C5-94A1-DE80FB9F7634
com.waves.driver.soundgrid (2.0.0) no UUID
com.valvesoftware.SteamInput (3083.39.62) DED4413E-CD8E-3E56-B0AB-7B3B20ECE4BF
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
Rhino plugins
/Applications/RhinoWIP.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp “Rhino Render” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_STL.rhp “STL Import” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/PlugIns/MPlane.rhp “MPlane” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_STL.rhp “STL Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/PlugIns/import_Points.rhp “Points Import” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_DGN.rhp “MicroStation file import: import_DGN” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_X.rhp “X Import” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_Points.rhp “Points Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X.rhp “X Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/PlugIns/Squish.rhp “Squish” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 6.15.19086.9026
/Applications/RhinoWIP.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 6.15.19086.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_M.rhp “Import_M” 6.15.19086.1002
Nice. You have an old-school “cheese-grater” Mac Pro. That is a bit of an old machine. A couple of things to try:
If that does not solve the problem, I would try deleting Grasshopper’s preferences. To do this:
Grasshopper …Better?
didn’t update to mojave, I’m reticent to update till the os has been out a while on account of my aging architecture and current stability (apart from this issue).
I removed the plugin folder and restarted the WIP, everything is copacetic. I’ll now add each plugin one by one as I need them and reboot to find the culprit. I have added quite a few over time, it’s good to go back to vanilla. thank you for your help!
FWIW, we have the same Cheese Grater and we did not have any issues updating to Mojave on this machine.
Cool! Good to know. If you find the culprit in the stack of components, please let us know.
I was just looking into upgrading to mojave and it seems my graphics card, the radeon 5870, is not “metal” compatible. So I am going to hold off upgrading the OS till I have a reason to upgrade my video card.
Ah yes, I forgot to mention that! We did have to update our card on the MacPro5,1 “Cheese Grater” for just this reason: Metal compatibility. We went with the AMD Radeon RX 560. We don’t use this machine for modeling however, so I don’t know how the performance would pan out, but I do know that it’s compatible.
things seem to be running ok for now, ill keep in mind the os disparity for future errors. next upgrade will likely be a better card that will support 3 screens + a vr rig, I use a PC for all of my VR and heavy rhino modeling these days but would like to have both ecosystems to work on moving forward.
