Grasshopper Components are missing
Hi all, really hoping someone could help with this one:
Rhino is working fine, I’ve got my licence running properly (the solution someone gave in 2020), not too sure what happened.
I’m assuming it’s because I tried to open a .gh file from my old computer, which had a lot of plugins installed. Reinstalling most of them, but the issue stays even when I open a new empty file.
Kind regards,
Brigitte
Hi Brigitte -
Please run the Rhino SystemInfo command and copy-paste the result here.
Hi Wim, much appreciate the help! <3
Rhino 6 SR35 2021-8-10 (Public Build, 6.35.21222.17002, Git hash:master @ 073ac7b225c67348731c6597127b9410126c3139)
License type: Educational, build 2021-08-10
License details: Cloud Zoo. In use by: brigittekock ()
Apple Intel 64-bit macOS Version 10.16 (Build 21D62) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro18,1
Machine name: MacBook Pro van Brigitte
Language: en-GB (MacOS default)
Apple M1 Pro (OpenGL ver:4.1 Metal - 76.3)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: n/a
Graphics: Apple M1 Pro
Displays: Unknown (255dpi 2x), Unknown (92dpi 1x)
Graphics processors
Apple M1 Pro (N/A)
Color LCD (1728 x 1117 @ 120.00Hz)
DELL P2417H (1920 x 1080 @ 60.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
Rhino plugins
/Applications/Rhinoceros.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 6.35.21222.17002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 6.35.21222.17002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 6.35.21222.17002
/Applications/Rhinoceros.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 6.35.21222.17002
/Applications/Rhinoceros.app/Contents/PlugIns/Displacement.rhp “Displacement” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/PlugIns/RhinoRender.rhp “Rhino Render” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 6.35.21222.17002
Hi Brigitte -
I’m afraid that running Rhino 6 on Apple Silicon processors is not supported.
Thank you Wim, would the best way to solve this then be to upgrade to Rhino 7?
Because, Rhino itself has no issues, it’s just Grasshopper that doesn’t work.
Hi Brigitte -
You should expect to run into issues with running Rhino 6 on Apple Silicon as well.
You might be lucky that it does what you want so far, but we don’t support it.
You could always download the Rhino 7 evaluation version and try that, but, I’m afraid that, at this point, it might be best to run Rhino 6 on an Intel mac. We are working hard to make Rhino 8 works satisfactory on Apple Silicon but, from what I can tell, Rhino 7 will suffer from the lack of OpenGL support on those machines.
Hi Wim,
Appreciate the honesty.
Ow…that really sucks! When is Rhino 8 likely to come out? :cold_sweat: Is there any way I could sign up to be a beta tester? :wink:
Kind regards,
Brigitte
Hi Brigitte -
I’ve seen someone mention next year, and while that probably isn’t a bad guess, we don’t operate with strict release dates. We ship when the product is good to go.
You automatically become a beta tester when you buy a license for the latest released version.
I would at least download the evaluation version of Rhino 7 and see if that gets you further than your current situation and take it from there.
