Grasshopper Visual Studio C#, Custom Outputs
I’m just getting started into C# development for GH and I’m trying to create multiple components that link together with the custom single outputs that carry multiple pieces of data, like a list/dictionary.
For Example,
For say a concrete beam design, I will have one main components that produces the solution and then I will have multiple components that go into that that define say Geometry, forces etc.
For the Geometry component I want it to only have one output and that output holds the data for all 3 or 4 inputs to be put into the main component. And it would be nice to be able to have the Geometry have a custom output “Beam.Geometry” that will then be read by the main component. Im just a bit unsure on how to go about this with the pManager.
Thanks
Dear @user2561 - what s your (nick-) name ?
Did you work through the examples in the SDK ?
https://developer.rhino3d.com/api/grasshopper/html/d113a9f0-6e27-46df-8316-2079c44382ac.htm
sounds like you should define a class for the “multiple pieces of data”.
this old post might help as a starting-point.
sorry i don t have a simple example with custom data to share.
Thanks
I tried having a go but since I’m pretty new to this I got a bit lost, any chance of a very simple example?
