Hie,
Anybody knows how i can update grasshopper to the version 1.10 with Rhino 7.
I like use the node “delete workset” and i caní found it.
Regards.
Hi -
There is no such version.
If you provide a source of the tutorial you are looking at, someone might be able to tell you which plug-in this component comes from.
Thanks.
I found this and i suppose that it was the Grasshopper version because i have the v 1.19 en Rhino Inside and not appear that node
Regards
Sure, i was working in Revit 2019. Thats the problem.
This component is available from Revit 2022.1.
On what Revit version are you?
