Hello. I am trying to make a surface between the two closed curves in the image, but it intersects itself. I tried with SWEEP as well with the same result. I have also tried inverting one curve, hoping they curves will connect in the same order, but with no result.
Thank you!
tudorvlad94
(Tudorvlad94)
1
laurent_delrieu
(Laurent Delrieu)
2
For 2 curves, cut the curves and do it with Rhino.
Or search the self intersecton and move the seam and loft.
Related topics
| Topic | Replies | Views | Activity | |
| Inconsistent Surface Creation from Curves | 4 | 316 | February 19, 2024 | |
| Lofting these two curves | 2 | 511 | April 28, 2021 | |
| Stop loft of 3D curve when loft self intersects? | 2 | 568 | June 14, 2021 | |
| Create a surface between intersecting curves | 7 | 371 | January 23, 2025 | |
| Self-intersected curve problem | 2 | 398 | December 3, 2021 |
