Grasshopper rhino8 does not support menu shortcuts anymore
in rhino7, typing the first letter of the word in the input parameter of a component would shortcut it.
For instance to flatten an input, we could do the following: rightclick on the parameter and type “F” on the keyboard.
This does not work in rhino 8 anymore. Is there a reason why? If not can this be fixed?
Hi -
This is on the list to be looked at: https://mcneel.myjetbrains.com/issue/RH-57216
Hi
Any updates?
RH-57216 is fixed in Rhino 8 Service Release 13
Hi @wim and @brian,
Sorry to bother you again but it used to work with sub-menu as well, for instance typing “WH” to set Wire Display → Hidden. Could you fix that too ?
Thanks
And I also noticed that “Invert” on a boolean parameter wroks only on the param component but not on the input parameters of other components:
