Anyone know what could be causing this error message?
Hi Denis - I do not get this message from the example script… what is the input, point objects or point 3d or? I set the type hint for x to be a point3d and wired a collectiion of points to it.
from operator import itemgetter
points = x
pSorted = sorted(points, key= itemgetter(1))
print points
print pSorted
a = points
Huh in the last WIP I still get this message. Actually no python scripts work in grasshopper.
Yeah input was a list of points. I was trying to right something that would let me sort by either x or y values.
@DavidRutten, @stevebaer - any ideas?
Do you have iron python 2.7.3 installed? I had a similar issue and that was the cause.
i do have 2.73.3 installed. I see about removing it to see if that fixes it.
That worked. I installed IronPython 2.7.7 and now everything seems to be working. Thanks again.
