Grasshopper Pull Error
Hey guys,
I have two problems:
  1. I’m trying to pull spirals on the srf.
    I’m getting strannge shift between upper and lower crvs pulled on srf.
    Do you have any idea why ?
  2. trying to loft items from two branches of one tree, no success. Do you know how to do it ?
Many thanks in advance!
Spirals Test.3dm (215.4 KB)
Spiral test.gh (9.2 KB)
That’s not an error.
Your surfaces are not tangent each-other:
(Zebra analysis)
More than tangency continuity a curvature continuity would be even better…
Then loft works with a list (a single branch) of curves. Each different list (branch) will be a different resulting surface.
If you add a “Flip matrix” before your loft component it will make something.
I think it would be best for you to first rebuild your polysurface into a single periodic surface with tangency/curvature continuity at the seam, and then work with that instead.
Thank you !
OK, I’ll work on the surface than.
And thanks for the tip with Flip Matrix, so useful! Loft works at it should now
:zap:
