Grasshopper preview dissappears when selected
Hello everyone,
is it just me or after the latest update of Rhino 6 the preview of Grasshopper geometry is very messed up? When I select a component in GH, it actually disappeares instead of being shown in green (or the color specified in the little menu). I experienced this on 4 different systems… What is going on? Is there some way to remedy this, or I have to downgrade?
Add some screenshots perhaps?
This just started to happen to me and I don’t know how to solve it. Did you find a solution?
Thanks,
J
So any selected (i.e. green) preview geometry is not visible? Settings are standard? No error messages in the Rhino command history?
–Me too! What happened?
[Yes David, selected geometry is not visible (nor any other!]
It seems to be file-specific to rhino file–I don’t have the issue in a NEW .3dm file in either v6 or v7.
v7 updated after I verified the same issue there, and everything’s back to normal!!! No idea if that’s all related, but happy for normalcy now.
Best I can tell, it started after opening either:
<SmartDivider01.gh> located here:
https://www.grasshopper3d.com/forum/topics/divide-curve-by-curvature-with-control-over-segment-size;
OR
<100125_DivideCurvebyCurvature_fix.gh> loacted here:
There were some custom graph previews in both, some old components that I replaced w/ the current ones–no idea if that’s relevant.
Only error messages I see in RH are related to CAD block attachment:
Unsupported entity type: AcDbMPolygon, MPOLYGON
Unsupported entity type: AcDbProxyEntity, ACAD_PROXY_ENTITY”
File is not new, and haven’t had the issue prior to today…
I closed gh & RH & started a new gh file from scratch, but same issue; haven’t intentionally changed anything besides preview colors (along time ago, no recent changes–docs above have default preview colors, but hasn’t posed an issue previously).
Opened up RH7 WIP & it’s happening there, too–haven’t used WIP for several days before just now.
Unselected:
Selected:
Version 6 SR24
(6.24.20079.23341, 03/19/2020)
Commercial
Win10Pro-x64
ha! just kidding! The issue seems to be related (at least somewhat) to the Discontinuity component:
When it’s set to “Analytical,” point-previews appear normally in existing ‘Top’ view, but C1 & C2 settings result in no-preview as shown above. ‘Perspective’ view seems normal.
I’ve had gh blow up my viewports before, but not so stealthfully!
Proposed workaround: delete viewport, create new one, set view.
I’m having the same issues here (Rhino 7). Found another post recommending to save as Rhino 6 - now i’m having the same problem in Rhino 6 !
Thanks to this advice of dtmurcielago I now know that I can see it In perspective view…
Any solution for this bug yet?
Try placing a point which has a higher Z coordinate than your other GH geometry in the file. Does that pop the selected preview back up again?
hi all, think I am experiencing a similar problem in rhino 7. Also, when baking from the brep component, it only bakes the red geometry and for some reason loses the first/end elements.
The problem is even more obvious on the second image where only one element is being previewed properly/baked.
In rhino 6 it seems to be working ok tho.
