Grasshopper Player and RhinoCommand
I use Grasshopper Player to create a toolbar. But I noticed that when we use a RhinoCommand which has options like for example “_Detail” then I continue in the options to change the scale for example, it works in the Grasshopper file but once activated with the Rhino button with GrasshopperPlayer Rhino command stops after “_Detail” and we don’t have access to options. I don’t understand why and I find it really unfortunate. but is there a way to achieve this?
Hi -
I’m having a hard time understanding how GrasshopperPlayer and Detail are used in the same macro. Could you please add details?
If I run this RhinoCommand from Grasshopper everything is fine. This selects my views, then it changes the scale to 50. Now if I create a button in Rhino that comes called this Grasshopper program with GrasshopperPlayer, the Rhino command hangs at “_Detail” because we don’t have access to the options Rhino commands when launched with GrasshopperPlayer.
With Grasshopper :
With GrasshopperPlayer :
Hi -
That component doesn’t appear to be a standard Grasshopper component. You might want to contact the author for help with this one.
The problem is exactly the same with a native C# component
