Can someone please explain to me how to use the grasshopper player? thank you
Hi Diego -
That’s a very broad question. Where are you getting stuck?
I understand, I want to know how to start using the player to be able to make videos of the models I make, is it necessary to use some commands on the canvas or does the player itself show the entire construction of the model? If you have any tutorial on this I would greatly appreciate it.
Hi Diego -
It sounds like you are looking for something else - animating a slider, perhaps?
The Rhino GrasshopperPlayer
command will simply ask you to find a Grasshopper file and will then bake the resulting geometry. This requires some modification of “regular” Grasshopper definitions so that you can provide Rhino input. The parameter objects to use can be found on the Params
tab under Util
