Grasshopper opens blank in Revit (Rhino.Inside) but works fine in Rhino
Hi everyone,
I’m facing an issue while using Grasshopper through Rhino.Inside Revit. When I open Grasshopper inside Revit, the component panels appear blank (no icons or content visible).
However, when I open Grasshopper directly in Rhino, everything works perfectly fine.
This issue only occurs inside Revit
i also tried reinstalling Rhino.Inside
Still facing the same issue.
Has anyone encountered this problem before? Any idea what might be causing it or how to fix it?
Thanks in advance!
Thank you for your reporting. There is a way to troubleshoot a GH plugin conflict is to start GH from the Rhino command line with command GrasshopperLoadOneByOne inside Revit and say No to all 3rd party gh plugins.
yes it works
but if i have to use the other plugin inside revit will they still work then
It looks that some GH plugins are not functioning properly in RIR. You’ll need to contact the developers of these plugins for further technical support.
oky thank you
