Has anyone figured out a way to see what index you are changing when editing a long list of data.
I know I could use replace index but I am changing them so often it would be helpful to simple open the edit panel and visually see which index I am changing.
A caveat to using the vuTreeList tool is that geometry can get in the way of seeing its blue and yellow results. Either previews from other components or worse, Rhino geometry which must be hidden. A related post is this one that adds a button to select a list of items.
An interesting idea, though it looks complicated. 1-based items instead of 0-based is unconventional, eh? More significantly, are you suggesting two methods for scrolling?
moving the scrollbar and
moving the cyan rectangle shown highlighting â3â
Thatâs a departure from UI norms that could be confusing. Does the cyan rectangle move to stay visible when using the scrollbar? Scrolling a list of interactive elements (checkboxes) is also non-standard, isnât it? Seems more difficult to implement than scrolling a static list.
I have long wished for the ability to designate UI elements in a cluster as âexternalâ, which would make them appear on the surface of the cluster. Not sure how they are arranged (by groups?) but the cluster would grow larger to accommodate them.
As to the pt_select_2020Dec7b.gh idea posted above, the text in that old post says âit is removedâ but thatâs a poor explanation, only true of the Cull Index component (green group, top right).
At the bottom right is a List Item component showing selected points as green. So as it says of selected items:
That was me being lazy. Would still be the usual 0-based.
I think just some way to scroll through a long list. Cyan was more just a static highlight to indicate whichever item is currently being scrolled over so that if youâre scrolling through a list of 200 points you can easily see the correlation between where the list is and which point is currently highlighted in the viewport.
The radio buttons were possibly a way to select items in the list and have automatic outputs created for them to eradicate the need for an input of indexes. But even without all the selection stuff just a scrollable list would be useful - make it easy to find objects in a sea of objects.
