I’ll updated my GH plugin from Rhino 5 to Rhino 6. Now, when I try to load GH with my plugin, I’ll get MissingMethodException for AddVectorParameter(). All other function AddxxxParameter are found, so I assume that the references to the GH_IO.dll and Grasshopper.dll are okay.
I call it e.g. as follows:
protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager)
pManager.AddIntegerParameter(“LC”, “LC”, “LC”, GH_ParamAccess.item, 0);
pManager.AddVectorParameter(“Direction”, “D”, “Direction”,
GH_ParamAccess.item, new Vector3d(0, 0, -1));
Does anyone have an idea what the problem could be? Am I missing something?
hmm, that method definitely still exists. Extract from the current source:
Public Function AddVectorParameter(name As String, _
nickname As String, _
description As String, _
access As GH_ParamAccess, _
[default] As Vector3d) As Int32
Merkwürdig. Does this happen when you try to load the plugin compiled against GH0.9 into GH1.0, or the other way around, or…?
I took the dll provided in the Rhino6 distribution. The version number in VS is showing 6.1.18037.13441. That is also the version number of Rhino6. (Before updating it, it was 1.0.0.20). Is it possible to have different GH versions while loading?
