Hello Everyone,
I have upgraded my Rhino License from Rhino 7 to Rhino 8. When I launch the Grasshopper I receive the following error. Any idea how to resolve this error?
Hi Muhammad -
When you use the Rhino SetDotNetRuntime command to switch to NETFramework, and restart Rhino, does the error go away?
Hello wim,
Can you please elaborate the steps?
Thank you very much, Wim. It worked ![]()
Hi Muhammad -
That’s good, of course, but it isn’t necessarily a solution. Especially not in the long run.
When new plug-ins - or new versions of existing plug-ins, are written to target new features in the .NET Core 7 runtimes, they will fail to run when you are running Rhino in the .NET Framework 4.8 runtime. If you have identified which plug-in failed to load in Core, you should contact the developer and request an update of the plug-in.
