hi , i get an error when i open this file0605.gh (643.5 KB)
The last time the grouping was added, the violet area continued to expand, causing an error
I have the same symptoms this time, I have saved, but the file does not open after crashing due to an error
Is there a way to recover the files?
And why does the grouping seem to be overlaid and cause an error?
I’m getting problems opening the file on Rhino6 too. Investigating further.
Can’t seem to get anywhere. I’ll have to enlist some of the C++ experts for this, which means Monday noon at the earliest. Logged under RH-46653.
Took a long time but I think I figured it out. The problem is that there’s a group which contains another group, and that group contains the first group. They’re cyclically nested, probably done through the ‘Add To Group’ menu item.
Good news is I can probably fix your file and fix this issue in Rhino6 onwards, but on Rhino5 this will always remain a fantastic way to crash Grasshopper.
This group fix is now logged under RH-46681.
@intrinsic5 try the attached file: 0605_fixed.gh (635.3 KB)
It has one missing component for minimal surfaces because I did not have that plugin installed.
It loads again here:
Thank you very much for your efforts !
