First, can the “text dot” component in rhino 8 beta grasshopper have a color parameter input so that we can modify the color separate from that which is assigned per layer? Second, when I bake the text dot from grasshopper using the “bake content” component in grasshopper, the text dot is not selectable in rhino space. text dots made in rhino are however selectable. please advise on the issue. also, it would be helpful if the “bake content” component had more input parameters such as layer, annotation attributes, materials, annotation styles, etc. Thank you.
Related topics
| Topic | Replies | Views | Activity | |
| Baking Text from GH to Rhino as regular text | 4 | 2653 | April 18, 2023 | |
| Grasshopper Rhino TextDot text color problem - always white? | 1 | 471 | September 15, 2023 | |
| No bake option on the text tags? | 3 | 1021 | October 4, 2023 | |
| Text Dots Bake when i attach a file (R5) | 2 | 365 | August 15, 2018 | |
| Bake or Export Text with given Size | 10 | 278 | May 10, 2025 |
