Grasshopper document list external dependencies / installed plugins, 3rd party libraries, version, referenced files
Hello again,
my goal is to document what external dependencies were used for a specific grasshopper document, so the result can be exactly replicated in the future when needed.
Goal:
  • get list of plugins (names) used in the canvaswith version
  • get list of user objects used in the canvas with version
  • exclude preinstalled grasshopper components/plugins
Some of the features are part of the “Pancake” plugin, with the features ‘Portability report’ and ‘Addon Manager’ but these are no grasshopper components and I can’t use them from my gh python component.
2020-11-13 10_00_15-Grasshopper - components
The Addon manager lists used addons and information about them, like the used version
2020-11-13 10_02_51-Grasshopper - components
The portability report additionally lists ‘referenced files’ that are used in the canvas.
Here is a snippet to get the names and types of the used components (from another forum post):
import Grasshopper as gh
names = []
types = []
for obj in ghenv.Component.OnPingDocument().Objects:
    if isinstance(obj,gh.Kernel.GH_Component):
        objName = obj.Name
        objString = obj.ToString()
        if objName not in names:
            names.append(objName)
            types.append(objString)
With this I still don’t know which components were used, at least not in a stable way. Something like Pufferfish.Components.Components_Point._1_Point.TweenConsecutivePoints indicates that a Pufferfish component is used, but how would I get which version of it was used? It is not in the list of plugins as acquired by the following snippet.
I could use something like
plugin_type = "Pufferfish.Components.Components_Point._1_Point.TweenConsecutivePoint"
plugin_name = plugin_type.split(".")[0]
to know which plugin was used, but what about component types like user objects etc?
Get installed plugin versions (adapted from a forum post)
import Rhino
d = Rhino.PlugIns.PlugIn.GetInstalledPlugIns()
for entry in d:
    plugin = Rhino.PlugIns.PlugIn.Find(entry.Key)
    if plugin:
        assembly = plugin.Assembly
        print(plugin.Name)
        print(plugin.Version)
This only leads to one external / ‘real’ plugin:
2020-11-13 10_24_02-Grasshopper Python Script Editor
Actually the info is saved in each Grasshopper definition. You can inspect the info by FileViewer.
Besides, you can find which plugin a component belongs to by GH_ComponentServer.FindAssemblyByObject
Try to enumerate clusters in the document and check references. Generally the idea is difficult to fulfill because once a user object is added to the canvas, it loses connections with the original GHUSER file.
Start Grasshopper + Pancake with Shift pressed, you’ll see a developer menu entry at the bottom of the Pancake menu. And there’s a “List of core components” and you will get a list with all built-in components. Also you can check the IsCoreLibrary property of a GH_AssemblyInfo, although it’s slightly more complicated to cover all situations.
Thanks!
asms = {}
for obj in gh.Instances.ComponentServer.ObjectProxies:
#for obj in ghenv.Component.OnPingDocument().Objects:
    asm = gh.Instances.ComponentServer.FindAssemblyByObject(obj.Guid)
    #print(x.IsCoreLibrary)
    if asm is not None and not asm.IsCoreLibrary:
        asms[asm.Name]=asm.Version
print(asms)
Result: {'Pufferfish': '2.9.0.0', 'Human': '1.2.0', 'MetaHopper': '1.2.4', 'GH_CPython': '', 'Pancake': '2.4.0.0', 'Kangaroo2 Components': '2.5.2', 'BullAnt': '', 'NGon': '2.3.0', '.Py Code Reader': '0.1', '': '', 'PlanktonGh': '0.4.0.0', 'Bifocals': '', 'Weaverbird': '0.9.0.1', 'Mesh Pipe': '1.0.0.0', 'MeshEdit Components': '2.0.0.0'}
This works now, but this still prints all versions and not only the ones in the canvas. I tried using for obj in ghenv.Component.OnPingDocument().Objects: but these objects got no Guid.
Do you know a way to use the document objects in the code snipped above?
obj.Guidobj.ComponentGuid
That’s it, thank you once again!
Thanks for this thread all of you above.
I’ve made the recommended changes to the code - please find attached.
Cheers
DK
230424_Find Dependencies.gh (9.4 KB)
I’m trying to limit the amout of dependencies in my scripts and this will help a lot.
Thank you.
My own version list the components and how many times they occur.
You can locate them on canvas using MMB → Find
List dependencies.gh (9.1 KB)
