am looking to divide a curved surface i lofted form lines into points and connect those points “you see them marked in a sequence numbering starting from 0 and in the same color”.
Initial surface created from curves.
Numbered and color-coded divided surface points
Intended connection between points
For the final model I would like to use those created lines to extrude them and give them thickness with a rectangular boundary from the top as you can see from my rough manually modeled shape using trip and spilt commands in rhino3d, image below
,At the moment I am stuck on creating the dividing the surface and couldn’t figure out how to connect them,
Here is my file any suggestion on the method also on how to achieve the final form using grasshopper it would be great.
gh Base Script clean.gh (9.4 KB)
gh Base Script.3dm (190.5 KB)
Thank you.
