Hi, there must be changed a lot with the new grasshopper. I had a good working model mostly with trigonometrical functions. But it seems the order, how curves and points are counted and indexed has changed? Some insights?
Best Jan
I really can’t tell from that image. The file looks pretty complicated so I doubt I’d be able to give you an answer even if I had the file without first spending a day digging through it.
Can you narrow it down to a specific component, or small group of components?
The possible explanations are:
This digging you described, is what I will do now, I only wanted to know if there where some major changes. There is not much documentation about this. I think this is a grasshopper bug. I will post my findings.
Thank you
Jan
I checked, it seems that taking a geometry and taking the brep edges and sorting out as a list is changing the index. So I had to chance the domain to get the right line.
Best Jan
Hi @JHA I reported it a few months ago, but without success. BUG - SURFACE TO CURVE @DavidRutten this could be fixed please.
thanks Erick.
I sorted all brep edges by hand to rescue the model, and again in the updated version 1.0.0007, everything is broken again. This sucks really. Sorry to say, but if I have to go through the gh files again and again to fix them.
best Jan
Hi Jan -
Perhaps this post helps explaining what’s going on:
Hi Wim,
thank you very much, I think this video addresses exactly my case! I was switching computers all the time and of course one time this occurred as I switched the version of grasshopper.
Best Jan
Hi @wim what do you think about this? Does the same thing happen on your computers?
@pavol @edsahergom
