I have a huge no. of objects and this is just a sample. When I convert the objects to grasshopper, the index no. are not in the order that I need. I get them like this pic.
I would like to change the index order to be like what is in this pic. Can I draw a line for the order of the index that I need? Or if there is any easier way?
Test_2020-3-8_re.gh (12.3 KB)
Index start from 0, but your sequence is the same.
Code is short enough to explain itself.
Let me know if not.
Note:
if you select curves on rhino and THEN right-click on parameter > “set multiple curve” , the order/sequence is lost;
if you, while nothing selected on rhino, do right-click on parameter > “set multiple curve” the selected object will be referenced in the same order you clicked them.
