I’ve created a couple of components in C# and I keep getting this breakpoint,
I’ve checked all of the inputs types and they seem to be matching. I have used classes as the outputs so i am using
Grasshopper.Kernel.Types.GH_ObjectWrapper forces = new Grasshopper.Kernel.Types.GH_ObjectWrapper();
to read them.
Have any idea what sort of thing I should look out for?
Thanks
Mitch
Hi Mitch,
as I know, this error is means that the data you send to RegistreOutputParams method does not match with the expected data type. Check pManager.Add… with the variable you send to this method. I do it usually via DA.SetData method.
Please post your component code and I will check it as well.
Ondřej
Hi Ondřej,
Thanks for this, I managed to find out the problem, it was due to the SetData outputs not matching the pManager. Here’s me trying to look at the inputs all this time
Thanks
Mitch
