Hi all,
I’m building a Rhino plugin and I’d like some geometry stored in the plugin to auto-populate a point collection in Grasshopper, and then open the Grasshopper editor on-screen.
However, I run into "Object reference not set to an instance of an object errors’ on both the ActiveCanvas, and (if I comment the former) the DocumentEditor.
How can I ensure these have been instantiated?
I have read the docs to no avail. Forgive me for being a novice.
using System;
using Rhino;
using Rhino.Commands;
using Grasshopper;
using Grasshopper.Kernel;
using Grasshopper.Kernel.Data;
using Grasshopper.Kernel.Types;
using System.IO;
using Ninject;
using PileDriver.Models.Interfaces;
using Grasshopper.Kernel.Parameters;
namespace PileDriver.Commands
public class IntoGH : Command
private readonly ISupportSystem _supportSystem;
public IntoGH()
Instance = this;
// Get ISupportSystem instance from Ninject kernel
IKernel kernel = PileDriverPlugin.Instance.GetKernel();
_supportSystem = kernel.Get<ISupportSystem>();
public static IntoGH Instance { get; private set; }
public override string EnglishName => "IntoGH";
try
if (_supportSystem.FoundationTracePoints == null || !_supportSystem.FoundationPolylineIsClosed())
RhinoApp.WriteLine("Please create a closed foundation trace first.");
return Result.Failure;
string scriptPath = Path.Combine(
Path.GetDirectoryName(typeof(IntoGH).Assembly.Location),
"Scripts",
"AutoPiler.gh"
if (!File.Exists(scriptPath))
RhinoApp.WriteLine($"Cannot find Grasshopper script at: {scriptPath}");
var io = new Grasshopper.Kernel.GH_DocumentIO();
if (!io.Open(scriptPath))
RhinoApp.WriteLine("Failed to load Grasshopper file.");
var ghDoc = io.Document;
if (ghDoc == null)
RhinoApp.WriteLine("No document found in the Grasshopper file.");
// Find parameters
IGH_Param foundationParam = FindParameter(ghDoc, "Foundation");
IGH_Param loadBearersParam = FindParameter(ghDoc, "Load-Bearers");
IGH_Param tieBeamsParam = FindParameter(ghDoc, "Tie Beams");
IGH_Param pilesParam = FindParameter(ghDoc, "Existing Piles");
if (foundationParam == null || loadBearersParam == null ||
tieBeamsParam == null || pilesParam == null)
RhinoApp.WriteLine("Could not find all required input parameters in the Grasshopper script.");
// Populate foundation polyline
var foundationData = new GH_Structure<GH_Point>();
foreach (var point in _supportSystem.FoundationTracePoints)
foundationData.Append(new GH_Point(point), new GH_Path(0));
((Param_Curve)foundationParam).SetPersistentData(foundationData);
// Add the document to Grasshopper's document server
Instances.DocumentServer.AddDocument(ghDoc);
// Enable solution
ghDoc.Enabled = true;
ghDoc.ExpireSolution();
// Set the loaded document as active AAAAAAAAAAAAAAAAAAAAAAAAAAAA
Instances.ActiveCanvas.Document = ghDoc;
// Show Grasshopper window
Instances.DocumentEditor.Show();
// Confirm successful load to user
RhinoApp.WriteLine("Successfully loaded and populated Grasshopper script.");
// Return success
return Result.Success;
catch (Exception ex)
RhinoApp.WriteLine($"Error: {ex.Message}");
private static IGH_Param FindParameter(GH_Document ghDoc, string nickname)
foreach (var obj in ghDoc.Objects)
if (obj is IGH_Param param && param.NickName.Equals(nickname, StringComparison.OrdinalIgnoreCase))
return param;
return null;
