Grasshopper "Align Plane" command in Rhino Common
Hi everyone,
I want to align plane in Rhino Common script like Grasshopper but couldn’t find any method for it. “Rotate” method is similar to functionality of “align plane” gh command but it requires angle and point, I want to use only plane and direction as an input.
Thanks for help
Best Regards,
Tahirhan
There is no such method because it is trivial to do it. Calculate the angle and rotate it. Or use this:
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Transform_Rotation.htm
private void RunScript(Plane p, Vector3d d, ref object A)
  double s,t;
  var pt = p.Origin + d;
  p.ClosestParameter(pt, out s, out t);
  double angle = -Math.Atan2(s, t) + Math.PI * 0.5;
  p.Rotate(angle, p.ZAxis, p.Origin);
  A = p;
You can also use NodeInCode to exactly generate same result as grasshopper components:
  var ap = Rhino.NodeInCode.Components.FindComponent("AlignPlane");
  if(ap == null) return;
  var ap_function = (System.Func<object,object,object>) ap.Delegate;
  var result = (IList<object>) ap_function(p, d);
  A = result[0];
AlignPlane.gh (15.6 KB)
You can use PlaneToPlane on the Transform class:
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Transform_PlaneToPlane.htm
Thanks a lot, I implemented the script to my code and it worked. I was trying to calculate the angle with normals and axis components but i see calculation of the angle is different in your script. Thanks!
