Managing planes - 3d arc
Hello everybody.
Here i have this line, and i got a point on it. the goal is showing the rotation of the point on the plane, with an arc.
I wanted to find the direction normal to the curve, to use as the tangent of the arc using the planes, but I couldn’t and thought of another strategy, like this.
i drew the points and the arc on rhino, preemptively. then i used the points to build the arc with grasshopper
studio-show rotation with arc.gh (10.4 KB)
Anybody with any suggestions how this could be done using ‘perp frame’ 'align plane or 'adjust plane ? I didn’t quite understand how to use those commands
Regards
Ascanio
studio-show rotation with arc_re.gh (14.1 KB)
i’m sorry, that’s not not exactly what i meant. I’ll post you an other definition that does what i want with all parametrized
@HS_Kim
take a look here
studio-show rotation with arc.1.gh (15.0 KB)
i just want to re-orientate those planes to get the blue normals and get the arc but i can’t figure out how to do it.
studio-show rotation with arc.1_re.gh (11.6 KB)
@HS_Kim
thank you for your time, this solution is nice but doesnt work in all cases for what i need.
I woul like the arc is always an arc of a circle.
let me try to explain. i want the arcs to describe the rotation of the point, so they must always be arcs of circumference.
I drew the arcs i want in rhino to try explain better what i mean.
This solution works when the angle of rotation is 90° like here, and coould be ok.
but the angle isnt always 90°. Let’s suppose i have different angles. For example:
angle< 90°
angle> 90°
Because obviously when you change the angle, the tangent you get in this way is different.
anyway in particular i would like to solve the problem using in some way the commands align plane/ adjust plane, is it possible?
I found a solution quick and dirty way to solve. however, any advice from you is welcome
using rotate 2 times, once to find the end point of the arc (variable) and once to find the direction of the tangent normal (fixed)
studio-show rotation with arc.2.gh (17.9 KB)
result with same angles of above:
regards
Check this as well.
studio-show rotation with arc.1_reV2.gh (13.8 KB)
very cool this one. i needed a bit of time to understand.
I ask you a question, starting from this definition I derived this.
now I’ll create a new topic.
