I’m running Rhino Compute locally (in a docker container on Windows). My goal is to run Grasshopper scripts and I have got that to work.
Now I’m trying to add Grasshopper addons, so I can use them in the Grasshopper scripts.
If I try to run a script that uses the Anemone addon I get the following error;
System.InvalidOperationException: Showing a modal dialog box or form when the application is not running in UserInteractive mode is not a valid operation. Specify the ServiceNotification or DefaultDesktopOnly style to display a notification from a service application.
at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
at Grasshopper.Kernel.GH_Document.InstallMissingObjects(GH_IReader reader, ObjectDeserialisationInfo[] info)
at Grasshopper.Kernel.GH_Document.ReadObjectList(GH_IReader reader, String collection, List`1 plugins)
at Grasshopper.Kernel.GH_Document.Read(GH_IReader reader)
at GH_IO.Serialization.GH_Archive.ExtractObject(GH_ISerializable target, String targetName)
at compute.geometry.ResthopperEndpointsModule.Grasshopper(NancyContext ctx) in C:\src\compute.geometry\ResthopperEndpoints.cs:line 87
at Nancy.Routing.Route.<>c__DisplayClass4.<Wrap>b__3(Object parameters, CancellationToken context)
I guess this is Grasshopper trying to open a dialog offering to download the Anemone addon. Fine.
So I tried to fix that by adding the Anemone addon file, i.e. anemone.gha, to the following folders:
- “C:/Users/ContainerAdministrator/AppData/Roaming/Grasshopper/6/Libraries/”
- “C:/Users/ContainerAdministrator/AppData/Roaming/Grasshopper/Libraries/”
But I still get the same error.
Does anyone know if that should work, or if there are any other things to do to make it work?
Thanks,
Martin
If you run Grasshopper in normal UI mode for that install, do you get a modal dialog?
Are you using the latest V7 WIP? I recently made the InstallMissingObjects function throw a descriptive exception instead of showing a dialog when running headless.
I’m running the docker setup so I have never run it with a UI. However, I have installed the latest WIP on another Windows computer and there I do get the popup if the addon is missing. But no popup if the addon is present.
As for the version I’m using the version in the Dockerfile:
ADD http://files.mcneel.com/dujour/exe/20200324/rhino_en-us_7.0.20084.11445.exe rhino_installer.exe
That was a bit old. So I just now tried the newest one and no crash! However, no output either. Not sure if it works or not, but at least I can take a step forward and investigate that.
I’ll report back my findings. Thanks!
You can add a callback to Rhino.Runtime.HostUtils.OnExceptionReport to get information about errors that may have occurred
I added a listener to the callback, but it does not seem to be called.
Rhino.Runtime.HostUtils.OnExceptionReport += (source, ex) => {
Log.Error(ex, source, "An exception occured while processing request");
Is there anything else to be doe for a Grasshopper addon to be found?
Is there a way to force detection? Or list what is available?
I tried moving the Grasshopper addon to the Grasshopper components folder:
"C:/Program Files/Rhino 7 WIP/Plug-ins/Grasshopper/Components/"
But then I got this error at startup:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.InvalidOperationException: Showing a modal dialog box or form when the application is not running in UserInteractive mode is not a valid operation. Specify the ServiceNotification or DefaultDesktopOnly style to display a notification from a service application.
at System.Windows.Forms.MessageBox.ShowCore(IWin32Window owner, String text, String caption, MessageBoxButtons buttons, MessageBoxIcon icon, MessageBoxDefaultButton defaultButton, MessageBoxOptions options, Boolean showHelp)
at System.Windows.Forms.MessageBox.Show(String text, String caption, MessageBoxButtons buttons, MessageBoxIcon icon)
at Grasshopper.Instances.get_ComponentServer()
at Grasshopper.Instances.RunHeadless()
--- End of inner exception stack trace ---
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters)
at compute.geometry.Bootstrapper.ApplicationStartup(TinyIoCContainer container, IPipelines pipelines)
at Nancy.Bootstrapper.NancyBootstrapperBase`1.Initialise()
at Nancy.Hosting.Self.NancyHost..ctor(INancyBootstrapper bootstrapper, HostConfiguration configuration, Uri[] baseUris)
at compute.geometry.NancySelfHost.Start(Int32 http_port)
at compute.geometry.Program.<>c__DisplayClass4_0.<Main>b__3(NancySelfHost tc)
at Topshelf.ServiceConfiguratorExtensions.<>c__DisplayClass2_0`1.<WhenStarted>b__0(T service, HostControl control)
at Topshelf.Builders.DelegateServiceBuilder`1.DelegateServiceHandle.Start(HostControl hostControl)
at Topshelf.Hosts.ConsoleRunHost.Run()
After some more testing of GH addons today we have found the following:
Weaverbird (installed with yak) works
MeshEdit (installed by adding .gha and .dlls) works
Still do not know why Anemone has problems. Is it due to opening a dialog? Or is it not properly registrered? Any ideas are welcome.
@MateuszZwierzycki may have a better idea than me, but I suspect we will run into this for several 3rd party components that were designed before compute existed. I will need to install anemone and test here to be able to give any feedback.
