While debugging rhino.compute + appserver vanilla(unaltered clone from github), has anyone run into when trying to open any of the example files?
rhino.compute throws this error:
[18:16:02 ERR] An exception occured while processing request
System.NullReferenceException: Object reference not set to an instance of an object.at SnippetManager.AssemblyPriority.DocumentServer_DocumentAdded(GH_DocumentServer sender, GH_Document doc)
at Grasshopper.Kernel.GH_DocumentServer.AddDocument(GH_Document document)
at compute.geometry.GrasshopperDefinition.Construct(GH_Archive archive) in C:\Users\vnatarajan\source\repos\compute.rhino3d\src\compute.geometry\GrasshopperDefinition.cs:line 174
at compute.geometry.GrasshopperDefinition.FromUrl(String url, Boolean cache) in C:\Users\vnatarajan\source\repos\compute.rhino3d\src\compute.geometry\GrasshopperDefinition.cs:line 93
at compute.geometry.ResthopperEndpointsModule.Grasshopper(NancyContext ctx) in C:\Users\vnatarajan\source\repos\compute.rhino3d\src\compute.geometry\ResthopperEndpoints.cs:line 91
at compute.geometry.ResthopperEndpointsModule.<.ctor>b__0_0(Object _) in C:\Users\vnatarajan\source\repos\compute.rhino3d\src\compute.geometry\ResthopperEndpoints.cs:line 23
at Nancy.Routing.Route.<>c__DisplayClass4.<Wrap>b__3(Object parameters, CancellationToken context)
127.0.0.1 - [2021-04-26T18:16:02.9068915+10:00] "POST /grasshopper HTTP/1.1" 500 -
Im still new to web-development so am curious- In order to us gh scripts as a web apps internally within an organisation for staff to use, will we require a production environment with core-hour billing or can a debug environment be set up for it?
One of the main things to avoid is anything that uses RhinoDoc.ActiveDoc, since by default, compute has no document. We’d need to know about your internal tools to understand what might not be working on Compute.
This is an open question that we don’t have fully resolved. Currently, our intention is that if you’re using compute in production (either internally or public facing) that you use core-hour billing. We are also talking about other ways of licensing compute for private use. We don’t have anything to share, yet, though.
