So I have to replace a stolen laptop workstation which inspired me to research what kind of upgrade in performance i can expect from a new machine. I’m pretty sure i will get the best processor available but I am at a loss when it comes to choosing a graphics card.
My last machine was a dell precision m4600 mobile workstation spec’d out as follows:
Intel Core i7-2820M Quad Core 2.30GHz 8MB,
8.0GB, DDR3-1600 SDRAM, 4 DIMM ,
NVIDIA Quadro 2000M with 2GB G DDR3,
500GB Hard Drive, 7200RPM,
It generally performed fairly well as a modeling station however it had some serious performance issues when i created a model with a lot of curves. I use rhino with rhinoCAM to produce engraved artwork with a CNC router. So I draw curves in rhino which i use as engraving operations in RhinoCAM as a way of precisely controlling the path of the CNC router. This results in files containing many thousands of curves at times. Rotating these models would have a serious lag and if i were to move a model like this I could sometimes wait minutes or more for the transformation to complete. This Kind of Lag was extremely stresssful considering i pay for use of the CNC equipment by the hour.
Another workflow that I use is to create a height-field from a grey-scale image. I run a parallel finishing milling operation over that surface with a V-bit at a step-over equal to twice the max depth of the Height-field. This would translate the image into the material on the table. Assuming my step-over is 1/4" I would have to sample the image with mesh vertices at least as tightly as the stepover (ideally double). so that would mean 16 mesh vertices per square inch. For a full sheet of material at 48 x 96" this means 73,728 mesh vertices on that surface. I noticed that in shaded mode the surface displays pretty well. But in wireframe mode its awful. But I need to look at the wireframe in order to see the detail.
So my questions are:
will a higher end video card help my situation?
is this possibly a VRAM issue?
there are options to get 1, 2 or 4 GB of Vram in the quadro cards for laptop. could I benefit from 4GB?
There is some debate about whether Quadro is actually better for rhino than GeForce. the simplified way that i understand gaming cards is that they handle more frames per second while workstation cards allow for greater detail. Is there a chance that a Geforce card might work better for drawing curves?
would more regular RAM help?
which piece of hardware is being utilized when displaying curves?
does this have anything to do with the way rhino utilizes resources?
Any insights are greatly appreciated.
Michael
