Global Edge Continuity – Issue
Hi @Gijs
I’ve been using your fabulous GEC tool again recently after a while. It’s been really useful and quite easy to use. I’ve noticed that some edges are failing G0 with some really high deviation values! Like edge no.22 in the attached file reads as being over 4mm out!
Looking at the geometry the edges look pretty adjacent. This is also confirmed with the Analyze curve deviation tool – all edges are within the 0.001mm file tolerance.
Let me know your thoughts..
Global Edge Continuity_issue.3dm (230.7 KB)
@sach I’ll have a look at the file tomorrow, but in general keep the G0 filter as low as possible.
Let me know if the info on this page makes it clear or not:
@Gijs
Very helpful article – thanks.
Noted about keeping the filters in check.
@sach In this case it was not the filter setting. The reason you get big deviations is because I currently don’t handle split edges very well.
The trimmed surface has a split edge, while the longer fillet has not.
For now you can solve this in two ways:
  • Split the edges of the fillet at the same points
  • Run MergeAllEdges on the surfaces
RH-85864 Handling of Split Edges against non split edges
Excellent – thanks.
Will keep that in mind.
Otherwise, the tool is great.
RH-85864 is fixed in Rhino WIP
GEC doesn’t find the common edge in this example:
2026-01-14_PatchFail.3dm (3.3 MB)
Try increasing the U and V spans of the patch.
I want to analyze something that I have built, not build something different in order to be able to analyze it…
@Charles the analysis of that edge does not meet G1 conditions and is therefore the edge is not shown in G2 analysis. You can however see the edge in G1 analysis mode. We can of course debate if this design choice is a good one, as it apparently is confusing.
I didn’t read the dialog sharp enough.
Sorry for the false alarm.
What you say makes sense.
About confusing; yes it is confusing, but I have no idea how to avoid the confusion.
I could decide to always show all the edges, no matter what continuity they have. But the idea is that you work your way through the model starting at G0, see also the help docs section recommended workflow, that Kelvin just made:
GlobalEdgeContinuity | Rhino 3-D modeling
Yes it is confusing. I expect an analysis tool of edges to show all possible edges, both in and out of tolerance.
That is one way to use the tool, but probably not how most users would use it. If G2 is of interest then I want to know which edges are G2 and which are not G2 in one step. I do not expect to need to use a multi-step complicated workflow. which depends on me noticing which edges which were previously shown are no longer shown.
What is the advantage of this complicated workflow over showing all edges with it obvious which edges are out of tolerance?
A fundamental disadvantage is not showing an edge which is out of tolerance is very likely to be misleading.
As soon as possible please.
Yes, +1
RH-91510 Show lower level results in all modes
RH-91510 is fixed in Rhino WIP
