There is a tool to check the geometric continuity of 2 curves, which tells you the angle deviation in degrees, so you can check how close to your set tolerances you are.
However, I cannot find the same tool for surfaces. Does it exist?
(I know about zebra and the other shading modes for visually checking, but what I’m looking for is the numeric analysis values.)
Hehe. Well, I managed to get different number (2, 3, 4 and 5s) after I extracted the surfaces and tried again, but I don’t understand what they mean. I guess this is perhaps a more rudimentary tool than your planarize/short edges tools that clearly draws nice things in the 3d viewport?
If you give it a surface with discontinuities, you’ll get some lovely stuff added, especially if you ask for details. Also info on the command line.
“Not G2_continuous. Maximum sampled curvature difference 0.212”
Oops, sorry. I thought it was something completely different. I wasn’t even aware that was something that could happen. I was looking for an easy way to mark continuities between surfaces, so I’ll continue to use V7 for that then.
