I used the old "global dimension scale " a lot in Rhino 4.
That control allowed to globally change the size of the dimensions (text, arrows etc) all at once).
Is there an equivalent way in version 5 ?
Thank you
Thank you
Dimension styles are what you are looking for I presume.
Document Properties-.Annotations->Dimensions
Thank you for the reply,
Yes, I know that the controls are there, and that I can change individually the text size, arrow´s dimensions, etc, create a custom style and so on…
But how do we, in a given style, change all of a dimensions´s sizes at the same time like in Rhino 4 with the old "global dimension scale " control ?
Regards
In Options/Annotation/Dimensions/<DimensionStyleName> you will find an entry “model space scale” which will do what you want I think (in model space only)…
–Mitch
Thank you but that doesn´t seem to work…
Got it now Mitch, thank you !
I was wrongly using the "model space text scale " box …
Under “layout sizes” the box “model space scale” does what I want.
Regards
I miss the old global scale in v4. The ability to change the scale of ALL the dim styles very quickly was very handy.
How get that in net?
Hey Rhinofan, I believe using the “Scale Distances” box and changing the scale does the global change as well.
I haven’t messed with the paper space though so I don’t know the difference in the two methods.
Thank you for the information !
