This is the error:
- The component generated invalid shapes data.
To fix this issue, simply rerun the component (set the “_runIt” input to “False”, and then again to “True”).
Tried it, didn’t work - any tips?
This is the error:
Hi @mahmoud.ramdane ,
Can you attach you .gh file please? Thank you.
Here you go!
gismo vienna [May-17 '22, 1428].gh (160.8 KB)
Thank you for the file.
Everything works fine on my PC. Check the screenshot below.
I am not sure why you get that warning. Try deleting the whole folder: C:\gismo\osm_files\Vienna_48.2077_16.3737_radius=1.0KM,
close Rhino, then run Rhino again, and run your .gh file again.
Ikt, but I need the buildings with the heights which it doesn’t seem to display unfortunately.
Thanks for your Help @djordje !
Which MapWinGIS version do you have installed?
MapWinGIS 4.9.6.1
I’ll re-install guismo and check again.
Don’t uninstall Gismo. You should try to uninstall MapWinGIS.
Try this:
Next until the end.C:\gismo\osm_files folderWorked like charm, thanks djordje!
