Is it correct that the “Merge Meta Data” node ignores all values after index 1?
Please see below snip where I attempt to merge 5 sets of data together.
When using the Merge Meta Data node it only merges 2 total values and ignores the other 3.
If I keep repeating the node I am successfully able to combine all data, though it does appear to ignore the order in which it was merged.
Is this expected behavior or a bug?
Thank you for your help!
