I’m not understanding the behavior of the merge component. When I use list created with repeat or duplicate data components and pass it through the merge, the order of the outputs is different from the order in the D1, D2 inputs and the result is grafted.
what I mean is that before the merge happens, you can already see the order you will get after flattening with merging. So in case you have a data tree with {0} and a data tree {0:0} they will not be merged into one tree since their data structures don’t match. The example above with the Suirify component changes the {0:0} data structure to {0} and then merge will keep the order since the data trees match.
One other way to look at it: if you graft the single item you get:
